| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
my amp powers down
while im listning to my radio my amp will just shut off and come back on in about 30 secs i have two p2 12" rockford fostgate subs in a ported box powered by a kenwood amp 1000w max and a sony headunit
all help will be appreciated |
Re: my amp powers down
also what should i set my amp settings too and the settings on my headunit
same thing used to happen...turns out my negative cable was loose @ the amp and that burned some of the strings but taking it out and putting everything back on, worked for me.
BTW wat's the RMS watts on your amp. caus I have 2 x p1 ported box with 300 watts rockford amp. just woundering if your amp can handle p2 which are like 300 rms each. |
The protection circuit will cut off the amp if - it gets too hot, it senses DC offset in the output, or there is a short circuit. As mentioned above, the amp will also turn off if the car voltage drops below a certain value (usually around 10 volts). |
