Old 02-02-2009, 07:11 PM
BOBCATJACK BOBCATJACK is offline
Running Problem
I Have A 95 Blazer 4.3. Engine Seems To Run Ok, At Highway Speed Seems Like Holding Back. Abs Light And Engine Light Both Stay On?
Old 02-02-2009, 08:43 PM
tempfixit tempfixit is offline
Re: Running Problem
Have you checked for codes since light is on?
Did abs and cel lights come on at same time?
Do you hear or feel any noise from brakes or wheel bearings?
Here is how to check for codes if not the OBDII system:
http://i644.photobucket.com/albums/u...eterminals.jpg
Jump terminal A & B with ignition switch off, once jumpered turn ignition switch to run without starting engine. Check engine light should flash, pause flash flash meaning code 12. Each code present will flash 3 times then move on to next code. Post codes.
Hope this helps
Old 02-03-2009, 06:08 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Running Problem
You might also check with your local auto parts store for a free diagnostic scan to get a code then like Tempfixit says, we can discuss it here.
