Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 02-02-2009, 06:44 PM   #1
skrizan
Flexible plastic brake line?
1995 S10 2.2 5 speed
I had a short section of brake line start leaking today from the junction at the axle to one of the rear brakes. I was at work and didn't want to risk driving it home. Dealer wanted $200, muffler man $50.
Picked it up from Muffler man and looked underneath and it is plastic flexible line?
Never heard of such a thing? Is this something new?
skrizan is offline   Reply With Quote
Old 02-03-2009, 09:24 AM   #2
rhandwor
Re: Flexible plastic brake line?
Most parts stores carry sections of brake line tubing of various lengths. Its a steel line with a plastic coating. These are high pressure lines I doubt if it was plastic. Normally these should be under $5.00 I don't know what they sold you but use approved steel tubing. You may have to use a bender to get the correct length. On a rear axle they normally have a spiral wound wire to prevent a stone from crushing them. I've also purchased a good section from a scrap yard.
rhandwor is offline   Reply With Quote
Old 02-03-2009, 10:31 AM   #3
j cAT
I never seen this before..is this a used vehicle?...only steel approved brake lines are used...I have seen rubber/spiral steel coverings, but these lines are all usually 1/4inch dia...with flare fitting...
normally the line or a section of line is removed then the replacement is flared into place...
j cAT is offline   Reply With Quote
Old 02-03-2009, 11:49 AM   #4
brcidd
brcidd's Avatar
Why not ask the Muffler man? Seems interesting- see if you can get a brand name..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 02-03-2009, 12:25 PM   #5
skrizan
This makes more sense, they installed it, I was in the middle of my work day 40 miles from home and didn't want to mess with it when they could do it for $50. I have only been able to peak under the vehicle and take a look. It must be plastic coated steel.
Thanks
