Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 02-02-2009, 04:26 PM
koonceman koonceman is offline
Question HELP!!! 2001 no pwr locks and windows. security sys, interior lights.
HELP!!! 2001 Oldsmobile Silhoette, 160,000 mls. At the same moment, the pwr door locks (wont work from the door switches or the clicker), windows (front and vent) wont function from the door switches or the overhead rear vent switch, interior lights wont turn on at all, alarm system (wont engage) and the radio goes off as soon as the key is turned off, when normally it stayed on until the doors open. **** Any idea what has caused these problems?
Old 02-02-2009, 08:13 PM
roadrunner2 roadrunner2 is offline
Re: HELP!!! 2001 no pwr locks and windows. security sys, interior lights.
Check the fuses and relays. Both the dash end fuse panel (pass side) and the fuse/relay box (mounted over the battery) show which components are related to which fuse or relay. (List on inside cover of each)
The problem with doing nothing is not knowing when you're finished.
Old 03-12-2009, 06:33 PM
danno7 danno7 is offline
check for burned wires on the ignition switch, located on the lower part of the steering column
