Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-02-2009, 11:31 AM
pfflyer46 pfflyer46 is offline
Unhappy 1998 Jimmy, no start, just gives a fews puts then cranks
I have read the numerous threads posted here about the no start problems had by by many. I have replaced fuel pump, reads a constant 61/2 psi now, was a very . Same results cranks putts a bit then just cranks more with a rare but ocasional putt. I replaced the expensive cpi spider this weekend, my thoughts were regulator not working properly, same result. I also tried a new crank sensor, no change. I must add did a complete tune up also plugs, rotor and wires all with no positive results. This vehicle is new to me, started and drove it with no issue when I purchased it but since I got it home a few weeks ago have not been able to get it to start and run. Any and all comments that could help point me in the better direction then I've been headed would be wonderful to me.
Old 02-02-2009, 12:04 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 1998 Jimmy, no start, just gives a fews puts then cranks
Check for a dead ignition coil and check the fuses for your EFI. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-02-2009, 02:19 PM
I had already checked the fuses, but no harm in checking again. I have a nice blue streak from my ignition module. I think maybe the term I used as it putts is confusing, what I meant by that is it is like it starts and then stalls right away. I can do this 5 or 6 times then it just cranks until I let it set for a bit and I can start the process all over again. My thinking is that it's not getting fuel after the initial prime from the fuel pump, according to the wiring schematic I have shows an oil pressure switch of some sort in the instrument panel but thats where I get messed up because the gauges are showing a rise in oil pressure from cranking.
Old 02-04-2009, 09:15 PM
Re: 1998 Jimmy, no start, just gives a fews putts then cranks
After further reading believe my problem has something to do with the passlock system. I didn't add that I had to replace the ignition switch key tumbler wasn't thinking that had anything to do with my no start condition. I read that the switch tumbler housing is where the resistor for the passlock is, but this problem acts like injection is being shut down by the passkey (passlock)system.The fuel pump was first problem but in the diagnosing stage the ignition key jammed up and no longer worked essentially compounding my no start condition. I attempted the re-learn procedure for the passlock but the security light goes out shortly after bumping the start position as described in the steps. The Jimmy did have a remote start system but removed it and put all back to oem standard. I'm totally at the mercy of the guru's here at the Automotive Forums on what my next step is to be. HELP !!!
Old 02-07-2009, 02:47 PM
HELP !!!!!!!!! still won't stay running, give me that first 2 seconds then dies. I tried for the sake of trying something the ignition module no change. Only couple things left that I haven't tried, cam sensor and PCM itself. Any help would be appreciated.
Old 02-10-2009, 07:37 AM
csmith89's Avatar
csmith89 csmith89 is offline
did it start having this issue before or after you did tune up?
Old 02-10-2009, 07:52 AM
I guess before because wouldn't start due to fuel pump issue, not sure why now, hence my asking the forum.
Old 02-10-2009, 08:06 AM
csmith89's Avatar
read the post 95 jimmy shuts off while driving it sounds like a similar problem to me....
Old 02-11-2009, 05:29 PM
I mentioned in my second post that I replaced the ignition lock cylinder (tumbler). I didn't think it mattered to use an parts store replacement but during my excessive troubleshooting found out that you have to use a GM lock cylinder. Anyway that was the fix.
