Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 02-02-2009, 11:30 AM
Gambler304 Gambler304 is offline
A/C & Heat not working properly in Front works fine in Rear
My Front A/C and Heat are acting up in the Front but work fine in the Rear. The Front will work fine for a while but upon acceleration shut off. I am thinking this is a Front Blend Door Acuator (I believe they are vacuum controlled). If this is in fact the problem where can I locate it and is it difficult to replace? Oh 99 Expedition 5.4
Old 02-04-2009, 07:03 AM
Bradthomas Bradthomas is offline
Re: A/C & Heat not working properly in Front works fine in Rear
I am having the same issue with my 03 Expedition. I thought I was going crazy, but when you accelerate it stops blowing but when you reach a "steady speed" it goes back to working again.
Old 03-03-2009, 11:08 AM
fusion27 fusion27 is offline
Question Re: A/C & Heat not working properly in Front works fine in Rear
got a 2003 exp and mind only blow on high in the front, the rear works fine, any help, thks.
Old 04-06-2009, 09:33 AM
kc5mhb kc5mhb is offline
My 1999 Expedition Eddie Bauer Edition blend door actuator was in fact electronic and had failed. The module consists of a motor which drives the blend door and knows the position of the door by the rheostat or potentiometer built on the board. That is what went bad on mine causing the A/C to not work properly in the front.
Old 04-06-2009, 09:37 AM
Sounds like a vacuum leak. If yours is vacuum controlled and you have manual controls, look for the tiny vacuum lines that come out near the heater core at the firewall under the hood. They are usually white and deteriorate from the heat. Chances are there is a hole in it somewhere between the firewall and where it connects to the vacuum tree. (Note: I don't have that model but my '96 Bronco is having the same problem and I've found at least 2 leaks so far and that hose was one of them.)
