Old 03-24-2003, 01:59 PM
plonger plonger is offline
How difficult is an mpfi swap ?
How difficult is an mpfi swap for ordinary people without big tech knowledge in mecanic but with an small base ? How long to do the swap for someone who never made swap ?
Old 03-24-2003, 02:25 PM
1990civic's Avatar
1990civic 1990civic is offline
the difficult part for you would be the wiring, but unless you get hooked up with the intake, and all the parts to do the swap with, its not worth the money, most of the time you can buy the whole engine for the price of the intake. also if you have an std be careful because i know for a fact that the heads from a std and a dx are different. you might have to get a MPFI intake off of a HF to do it right. but remember this is coming from somebody that has never done the swap, but i did rebuild my engine, so i have some knowledge.
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
Clear Tail's (no altezza's here)
http://www.automotiveforums.com/img.php?129408DSC00972.JPG
****hopefully not the end****
Old 03-24-2003, 03:16 PM
antiguabill's Avatar
antiguabill antiguabill is offline
this might sound really dumb, but my civic has a carburettor, can you swap mpfi into that?
Old 03-24-2003, 03:24 PM
SIvic SIvic is offline
dpfi-mpfi swap:
I did this swap on 2 civic dx's
and converted mine when I went with the ZC sohc.
honestly, Its an easy swap, but sometimes hard getting the parts for the swap.
you need the following parts:
88-91 intake manifold complete with throttle body & injectors
88-91 distributor can be crx hf/si or civic si
88-91 injector resistor box w/ wiring (makes it easier to graft)
88-91 pm6 ecu Si or use 88-89 integra pg7 or 90-91 integra pr4 works
88-95 intake manifold gasket (canadian tire)
you can also use 92-95 intake manifold.....currently on my setup..
:smoker2: pass dat shiat :sun:
Old 03-24-2003, 03:29 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i think it might be possible but its prolly difficult too but i think ne things possible
Old 03-24-2003, 04:14 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I have a D15b7 in my garage out of my 93 Del Sol. I will sell the intake + fuel rail and injector. Let me know if anyone want anything off of the motor. It's compete minus a alternator.
Old 03-24-2003, 06:37 PM
1990civic's Avatar
carburator to mpfi should be the same as dx to si, except you will need air cleaner back to intake manifold, and i suggest a whole new wire harness.
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
Old 03-24-2003, 07:40 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
you would also need a efi fuel pump if im not mistaken
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 03-25-2003, 05:14 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
I have a 88 CRX si intake
88 crx si distro
88 crx si ecu (pm6)
88 Crx Si wiring harness (most of it) and resistor box all for sale
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 03-25-2003, 06:05 AM
1990civic's Avatar
yes the fuel pump is a must.
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
