Old 02-02-2009, 05:36 AM
polarzak polarzak is offline
2000 has troouble starting sometimes
MY wife's 2000 3.8 sometimes will not start, hot or cold, unless the gas peddle is pushed right to the floor. I happened three times last week. The first time it happened, she called, and it was the first thing I thought to tell her to do, having used this method on old carburetor cars when they flooded. Is the Lesabre getting flooding? It has always started, even remotely, without touching the gas peddle. It has about 200k miles on it and runs perfectly
otherwise.
Anything I need to change or clean to stop this minor nuisance?
Thanks.
Old 02-02-2009, 06:21 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2000 has troouble starting sometimes
I would first check & clean the idle air control (IAC). Do you have a scanner that will read live data?
Old 02-02-2009, 09:30 AM
No...the only scanner??? I have reads OBDII codes and there are none in memory. I will locate (I hope) and clean the IAC.
Thanks for the reply.
Old 02-02-2009, 10:12 AM
HotZ28's Avatar
AF Moderator Elite
Here you go, we will make it easy to find!
Old 02-02-2009, 11:45 AM
Ahhhhh, you are a gentleman, Sir. I thought it would be that area. Really appreciate you making it easy for me. Will let you know if cleaning does the trick.
Thanks!!!
Old 02-10-2009, 06:22 AM
Cleaned and so far so good. Thanks HotZ
