Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-01-2009, 08:15 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Smoking is bad
Especially when I don't know why.
Took my motor out, replaces clutch, flywheel, oil pan & gasget, axles, etc.
Put it back in, but with the wrong power steering fluid. But that's not the problem. I just got gas for it, and I pulled into the garage and turned the light on, and there was smoke coming up from under the intake manifold area. At first I thought it was just oil and stuff from disconnecting hoses that burned off. But then I started listening and I kept hearing a sizzle sound every few seconds. So something is leaking on the exhaust (mu guess) but I'm not sure what. Any ideas what it could be. I know putting the wrong PS fluid in can mess up the seals throughout the power steering, but would that cause leaks?
If anyone can help me I'd REALLLLY appreciate it. Thanks.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 02-01-2009, 09:52 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Smoking is bad
My first thoughts on the under manifold sizzle, and smoke, is a coolant leak. There are quite a few coolant lines up under there that can leak. Oil usually does not sizzle when it hits the exhaust.
Old 02-02-2009, 09:32 PM
Re: Smoking is bad
Yeaahh. I looked under the car about 10 minutes later, and there was a lovely puddle of coolant.
So while the system was pressurized, I pushed on some hoses, and two have little cracks in them, and, when presses on, they pee coolant out.
Me: No you idiot.
Me: FAIL
