Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 02-01-2009, 02:50 PM
venturenot venturenot is offline
Creaking sound coming from steering column
I hear a fast clicking creaking sound everytime I make fairly sharp turns to the right or left. It is only noticable at slow speeds and especially noticable when in reverse turning out of a parking space. The noise sounds like it is directly inline with the steering column and coming from the very front (towards engine) under the dash. I checked the power steering fluid and it is fine. I do not hear the sound at speeds above about 2o miles per hour. It is definitely not the groan that you hear with low power steering fluid but rather like someone is stepping on a very creaking board that sometimes includes a rythmic creaky click. Any ideas? Thankyou.
Old 02-02-2009, 08:24 AM
LMP's Avatar
LMP LMP is offline
Re: Creaking sound coming from steering column
I have something that could be close to this description: it is the rubber bellows over the tie rod that follows the movement by slipping with discrete increments instead of a continous slip....may be not your case, but check that out first...then, the ball joints if they have same age as car (1998) (riveted, originals; bolted on: aftermarket)
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-05-2009, 11:46 AM
Thanks for the help. The front sway bar was replaced and the noise has gone away. Now waiting for the next problem. The car runs great yet there always seems to be something.
