Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 01-31-2009, 09:57 PM
meliusk meliusk is offline
Question DRL won't shut off when car locked
My Daylight Running Lights on my 2002 Buick Rendezvous CXL have remained on and will not shut off when the car is stopped and locked. Have to disconnect battery to shut them off. Is there any other way to turn them off?
Has anyone else encountered this problem?
Old 01-31-2009, 11:07 PM
discnik discnik is offline
Re: DRL won't shut off when car locked
Fuse 14,( 15 amp), in the underhood fuse block should be the one for your DRL's. Does the DRL relay feel hot ?
Possible sticking relay ?
Just a thought.
Old 02-01-2009, 11:14 AM
Just a thought.
Thank you for your suggestion discnik. Will have to wait til it happens again to check it out. Not sure where the relay is. I would guess the fuse is close to it.
Old 02-01-2009, 09:21 PM
Look in the owners manual for the relay and fuse location.
Good Luck.
Old 02-06-2009, 07:40 PM
Good Luck.
Thanks to you we located the relay and replaced it. We are hoping this solved the problem. So far, so good! Many thanks discnik!
Old 02-07-2009, 12:33 AM
Hope it continues to work. Your Welcome.
