Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 01-31-2009, 09:13 PM
ecamc ecamc is offline
Send a message via AIM to ecamc
Question Gear indicator problem
My son just bought a used 98 Splash (automatic). The only weird thing is that the gear indicator never leaves Park. Not so bad, it doesn't take long to figure out what gear you are in, but just wondering if anyone has ever had the same issue, or knows how to fix it.
Thanks,
EC
Old 02-03-2009, 07:07 AM
yotermanic yotermanic is offline
Re: Gear indicator problem
Take the clamshell off the steering colun and the kneeboard off the driver's side dash. This indicator works off of a cable that passes under the steering column and attatches to the indicator on the instrument cluster. Chances are, the thing has become disconnected or the cable is broken. Lots of times these get broken when someone removes a steering column or an instrument cluster and is not careful to remove the cable beforehand. If the thing has just become disconnected from the shift lever, however, it is an easy fix that'll make you a fifteen minute hero.
Old 04-25-2015, 08:20 PM
timd timd is offline
This works on a 2002 Ranger! The plastic adj nut had stripped but I was able to space it so that it is accurate again.
Old 09-26-2016, 09:29 PM
Keg914 Keg914 is offline
Had the same problem with a 2001 Ranger XLT. This is a good solution. You can also find videos on YouTube that help.
Old 09-30-2016, 09:22 AM
max_10 max_10 is offline
My friend had the same issue, don't know what it is though?
_________
Max<<_10
