Old 01-31-2009, 01:54 PM
JJThad JJThad is offline
Re: OBD0 to OBD1 conversion having problems.
i HAVE A 90 ACURA INTEGRA AND HAD ORDERERD A DISTRIBUTOR. WELL COME TO FIND OUT THAT IT WAS A OBD-1 DIST. SO THEN I WAS WONDERING WHAT ARE THE EXACT PARTS THAT I NEED TO DO THE CONVERSION AND IS IT A DIFFICULT CONVERSION??? CAN ANYONE HELP???
Old 01-31-2009, 05:23 PM
KoDKingVegeta KoDKingVegeta is offline
Iv got a feeling that Dropzone will be here to answer your question.
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 02-01-2009, 04:39 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: OBD-0 to OBD 1 Conversion
Actually, I've never really been totally sure on the upgrade parts for swapping to OBD-1... I'm pretty sure you just need the ECU and a jumper harness though. You can get full instructions w/ a jumper harness from HaSport and RyWire, plus several other companies.
I do know that if you're only going to do the swap to negate having to send the dizzy back and get the right one, DON'T. You should never do unplanned work just to negate a few dollars out of pocket, you'll always end up spending A LOT more than you thought or planned, and there is no immediate return for swapping to OBD-1 unless you plan on tuning for boost or something, or using Vtec
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 02-01-2009, 11:57 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Distributor, ECU and a 4-wire O2 Sensor are the 3 things off the top of my head.
But like Dropzone said, don't do it just to negate sending the distributor back to get the correct one. If you have other reasons, go ahead. But you are looking at spending money on a new ecu, o2 sensor and a conversion harness.
Tony
91 Civic Sedan DX - Stock 287k Miles
