Old 01-31-2009, 05:27 PM
quackmandude quackmandude is offline
sqeaky brakes
not a huge problem, but one that i cannot seem to solve. i have new stillen rotors and almost new brake pads, theres a lot of sqeaking coming from my drivers side from brake and its starting toget annoying, it started before i replaced anything and it went away for a bit afterwards but now its back, help, lol
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 02-05-2009, 10:15 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Re: sqeaky brakes
does it sqeak when driving or just brakeing? did u lube ur guide pins? or ur pads need to be replaced with lest dusy pads. with those slotted rotors u wanna make sure ur brake pad surface edges are rounded not flat.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 02-23-2009, 01:52 PM
Re: sqeaky brakes
sry it took so long, the guide pins were lubed befor i put them in, but its only sqeaking on one side, drivers. its only when im braking, and now its starting to feel a lil bit warped. its not bad but it vibrates a bit when im braking
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 02-24-2009, 11:49 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: sqeaky brakes
Sounds like you have a glazed rotor. Did you bed the brakes properly? Also, did you use anti squeal on the backing plates of the pads?
