Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-31-2009, 04:29 PM
wrong83 wrong83 is offline
'02 Bravada- acceleration NOISE!
Hey everyone I just recently replaced my fan clutch. When the fan started sounding like a jet engine I also noticed another noise that initally sounded like it was coming from inside the rear part of the car. After I rolled down the windows and listened to it, it sounds like it's coming from under the car. I only hear the noise when I'm accelerating in gear. The noise changes tones and frequencies while I'm driving, it's quite wierd. After I got the fan clutch replaced I figured the noise would go away but it did NOT. Has anyone else experienced a noise which I can best describe as a whining one, but again the noise changes periodically. It doesn't sound like it's coming from the engine, it sounds like it's in the muffler almost. Thanks!
Old 01-31-2009, 06:12 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: '02 Bravada- acceleration NOISE!
I've had transmissions that whined. How many miles do you have on your Bravada?
Old 01-31-2009, 09:52 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
could also be the rear differential, check the fluid level. once you get a whine there you can replace the cover gasket and fluid and live with it but a rebuild is the only way to get rid of it. also check the u-joints
Old 02-01-2009, 03:19 AM
There's 77,000 miles on it, is it normally to hear different whine tones and such from it the rear differential. If I give it gas and then let off of it and it cruises for several seconds it sometimes goes away even if I'm cruising at 20 mph.
Old 02-01-2009, 03:33 PM
ericn1300's Avatar
AF Premium User
the back lash in the gears becomes greater as they wear and the surfaces get damaged if you run low or out of oil. the gears are biased in one direction when accelerating and the opposite when de-accelerating which cause different noises.
Old 02-02-2009, 05:31 AM
The noise hasn't really increased in sound, it's the same noise level as a week ago. I'm still questioning whether the oil level is low and it's the differential that's causing the noise.Thanks for your help. I'm going to take it in and have them check the differential box.
