Old 01-31-2009, 12:32 PM
thadigg24 thadigg24 is offline
MANY problems - '98 Cav
Had this car from my brother...inherited a lot of problems i would like to fix...if you have a suggestion for any please help me out here. So far i've replaced the head gasket, water pump, and a couple belts.
For starters.....the E-brake doesn't work properly. The light is on, and it doesn't do anything if you pull it unless your on ice (slides the back around) or going extremely slow.
Secondly.....the lights on the speedometer, gas gauge don't work. I obviously checked the fuses, but they all were intact and still no lights.
dont want to overwhelm on my first post so ill end it here....i hope you guys have some suggestions!
Old 02-01-2009, 04:21 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: MANY problems - '98 Cav
The e-brake is most likely just out of adjustment since it works a bit. Pull the drums and turn the adjuster until you feel a slight drag when turning the drum by hand.
If you have some lights, the bulbs are burnt out around those guages. Replace them all if you have to take it apart. If it's got no lights at all, check for power to the dimmer switch and that you have a good ground.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
