poor mpg 91 PA
My 91 PA uses a lot of fuel. Measured over a couple of thousand of miles, it averages about 20,5 mpg, and this is 80-90% highway.
I already replaced the airfilter, spark plugs, plug wires, coils and o2 sensor. Also I didn't drive faster then 80. When I calculate the mpg from the fuel gauge it is about 25, but when I actually fill up the tank it always goes down to 20. How do the people who get good mpg measure this? I have noticed that when the pump stops when filling up the tank, there is still room for 4-5 gallon if you poor it in slowly. Could this difference account for the 30 mpg figures people are reporting? What else could cause the high fuel consumption? |
Re: poor mpg 91 PA
What kind of highway travel are you talking about. Do you mean highway travel as in interstate travel? If your trips are around 15-20 miles you won't get 30mpg. You have to take into accound engine warm up time and inefficiency at the time. Long trips cancel this out.
When I use to take the interstate to work I only averaged around 20.5-22mpg in a 16 mile one way trip. I have seen as high as 34mpg and as low as 25mpg on long trips. As far as gas pumping goes if the low fuel light comes on you have to pump at least 13.5 gallons (18/4= 4.5 gal = 1/4 tank). Usually i take my average at that time (miles driven/gallons used) and can roughly estimate my gas mileage before even going to the pump. I always reset the trip meter when filling up. Also I have observed that the gas hand is about a gallons off. If you pump gas right at half a tank you only need 8 not 9 gallons and the if you pump it at the next mark below you need 9 gallons. Also when pumping gas make sure that the fas tank is either flat or sloping away from the filler tube otherwise it won't fill up to the proper level. I have got inaccurate readings several times due this. Don't feel bad though I'm only averaging 19mpg
95' PARK AVENUE 168,000 MILES ![]() ![]() Warning
: Listen at your own discretion |
Re: poor mpg 91 PA
Re: poor mpg 91 PA
Thanks for your answers. I often do make 20 mile highway trips, and rarely more than 60 in one go...
When I made a 350 mile highway trip, I got about 22,5 mpg. I mostly go to the same gas station. Note the 91 doesn't have an economy gauge... It's good to know the milage is normal then. I forgot about this thread where our milage is close to the "official" combined figures. Just want to make sure I'm not forgetting anything what could cause the milage to be to high in the PA, gas overhere is expensive enough as it is ! |
Re: poor mpg 91 PA
That gas gauges aren't linear in their readings. I replaced the fuel pump in the tank on my 98 and have an AC/Delco replacement, but the gas gauge is closer to linear than any I've seen. If it's down the first quarter it will only take about 4 gallons (18 gallon tank). The way to compute is just keep a note book of the odometer reading and the number of gallons you put in. Over 3 or 4 fillups any error due to car position and not filling to the same amount of air bubble volume in the top of the tank will be averaged out. You don't mention how many miles on the motor. It may be some age and mileage wear is affecting the mileage. If it were my car, I'd pick up a quart of Rislone oil additive (looks like a bright yellow quart of oil) and add half the quart about 500 miles before my oil change. Then repeat next time with the other half. It remove deposits on rings that might affect efficiency. Also I'd use Techron Fuel System Cleaner. The 12 oz bottle is for up to 12 gallons of gas (our tanks are 18) or the 20 oz bottle is for up to 20 gallons. The 12 oz bottles are free with a mail in rebate at Autozone right now. http://www.autozone.com/images/in_ou...on_0115_09.pdf The rebate coupon is for purchases up through Feb 12. Note that Walmart and other stores have this also. There is a Techron Injector Cleaner that's cheaper, but I use the Fuel System Cleaner. These are both things I use in my own Buicks about 3 times per year. |
Re: poor mpg 91 PA
i want to figure out the mpg on my park ave also. i drive 50 miles total on the highway each day going and coming from work. i normally drive with the car in just the regular drive gear. is it better to use the drive gear with the overdrive circle around it, or just the regular drive gear to get the most fuel efficiency?
i never knew a buick could ride as smooth as a cadillac and use cheaper gas buick>caddy(well at least until i buy a caddy lol.
Re: poor mpg 91 PA
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: poor mpg 91 PA
i normally drive from 55mph to 75 mph(85 in the tunnel ) on my way to work. i will leave it on OD now. thanks.also since i work late at nights, there are times when traffic is nonexistent and i don't have to brake for like ten minutes.
Re: poor mpg 91 PA
