Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-30-2009, 03:59 PM
garync1 garync1 is offline
2002 Cr-v 4 wheel disk brakes.. replacement
Hello! I just did a brake job and front rotors replacement.. Just to let you know if you have trouble removing the Phillips head type screws.. Just go ahead and drill them out.. Took about 5 min and you don't need them..I Only replaced the front rotors. But I changed all brakes front and back.. Very easy pad assembly to work with.. Just wanted to give a heads up on the screws that go to the rotors.. Stupid to use Phillips head type screw there..
Just when you think you are done. Your not!! Clean the tools. Then you are done.
Nothing impresses a single mom better than a single dad who drives a minivan.Just kidding
Old 02-12-2009, 08:40 PM
MrWrongsalive MrWrongsalive is offline
Re: 2002 Cr-v 4 wheel disk brakes.. replacement
I wanted to add to that one, if you want to get the retention screws out of hub an impact driver is a very useful tool to use. Sears sells them for not alot of money.
Old 01-01-2010, 09:50 AM
aggreX aggreX is offline
18V impact driver definitely works great but if you already damaged the ez to damage screw then drilling or bolt-remover is the next choice
