Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 01-30-2009, 02:37 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question FMIC sizes
Ok so for my build I'll be running my little t3/t4 hybrid at ~15psi for daily and then max it out (supposedly ~20psi) at the track. Now, I'm running a FMIC measuring about 17"x6"x2.5" (pic below).
The question is, do you think the IC this size will be able to handle that kind of power? Also keep in mind that I will be upgrading to a bigger turbo eventually (probably another t3/t4 variation) and would like ~25-30psi track use. I know those numbers are high... but that's a goal. Should I upgrade? I don't want to lose power because my IC is too big. Also, I'm running 2.5" piping. Should I consider bigger also?
Picture to show size.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-30-2009, 07:57 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: FMIC sizes
That looks like it would be on the small side for what you're running, but it should be fine. When you upgrade turbos though, you'll want to upgrade IC's too.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-31-2009, 12:09 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: FMIC sizes
This is all just speculation as I really dont know what I'm talking about, but:
That IC should be fine for what your doing now. But since you are planning on doing alot more modding, I would say step up to a bigger FMIC. But 2.5" piping should be plenty.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-31-2009, 11:03 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Re: FMIC sizes
would 3'' ic piping actually cause any harm? or is it a matter of, more area to fill inside bigger pipes the better?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 02-01-2009, 12:31 AM
Re: FMIC sizes
You'll loose some air flow velocity.
Caleb
vanilla gorilla
Old 02-01-2009, 10:33 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: FMIC sizes
I think that should be good for your setup now. Eventually when you upgrade turbos you can do some test runs on this intercooler to see if it'll work sufficiently for you or if you'll need to upgrade it. No sense in going too big if you don't need it. Like this retard. Bigger is not always better. lol...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-01-2009, 10:39 AM
Re: FMIC sizes
so 2.5'' is prime
nice
now does anyone know where to find powder coated pipe pieces where i can piece togehter my own plumbing?
i keep finding plenty of stainless random pipes to choose from, but havent been so lucky finding black pipes..
Old 02-01-2009, 10:43 AM
Re: FMIC sizes
so 2.5'' is prime
nice
I would go stainless piping over powdercoated. The stainless will reflect heat much better.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-01-2009, 10:55 AM
david-b's Avatar
Dave is THAT guy
Re: FMIC sizes
Not necessarily. Powdercoating is thick enough to keep heat out and keep whatever inside. Stainless if anything will heat soak much quicker than aluminum powdercoated pipes.
Junkie:
Check all over eBay. I found mine in black on eBay for a decent price with the IC
75 Monte Carlo
Old 02-01-2009, 11:01 AM
Re: FMIC sizes
I remember we all had this discussion a few years back on here and I thought for sure the outcome was that powdercoating was bad for heat?... I need to find that thread...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-01-2009, 11:03 AM
david-b's Avatar
Dave is THAT guy
Re: FMIC sizes
My powdercoating shop said that ceramic coating is the best for keeping heat out (thus why I got my IM ceramic coated) and that powdercoating still keeps heat away but not as well. It's still better than bare pipe. That's what they said.
75 Monte Carlo
Old 02-01-2009, 11:07 AM
Re: FMIC sizes
Hmmm I almost wanna go about this whole discussion again and find out the best for sure... I know ceramic coating is good for heat but also more expensive...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-01-2009, 11:25 AM
david-b's Avatar
Dave is THAT guy
Re: FMIC sizes
Ya was ~$130 for the IM compared to like the ~$70 for VC.
75 Monte Carlo
Old 02-01-2009, 09:51 PM
Re: FMIC sizes
When you buy a high dollar FMIC kit from one of the big brands....what is the treatment on the pipes? I dont think any of those kits use bare piping. I run bare aluminized piping on my LICP's, just because...I'm not sure why, I just did. I have the upper pipe painted because when I bought it is was powdercoated a tacky red.
Caleb
vanilla gorilla
Old 02-02-2009, 10:14 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: FMIC sizes
The intercooler you have will be fine for your setup now. I would plan on upgrading when you go to the bigger turbo.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
