| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Possibly blown Pioneer 6900UB cd player
Ok....so I went inside my dash to try and fix a problem and ended up even more screwed
When I cut my car off...and back on none of my audio settings ever saved. So I was reading...they said the red and yellow wire could be backwards or something. So im took my player out and looked at harness try and see maybe if I did do it backwards......well, nothing seems backwards But as I was moving wires around......my red wire was bare (yeah, I know....bad bad) and maybe one or two more.....the ACC (battery, yellow) and Ground (black) was NOT bare, all wrapped but somehow........some wires touched each other or possible it grounded out on bare metal or SOMETHING But sparks flew.......and player won't turn on anymore No smell came from the player........no smoke, nothing, seemed fine, but won't power on anymore It has a 10-fuse on the ACC/yellow line...but its not blown and I know its feeding power (which means the fusebox radio 10a is not blown either) I hooked up another player, just to see if it gets power and it does (did not play anything, just tested for power) On Pioneers...known for on the Red wire......it has an inline resistor.........could that be blown causing the problem? can I just bypass the resistor and run the wire straight? Or......could you enlighten me on anything else I could not be thinking of? Thanks |
Re: Possibly blown Pioneer 6900UB cd player
I think they have a small fuse on the back of the player itelf
blahh!!
thx for response im prob. gonna have to take to repair shop.....prob. something like internal fuse blown or something out of my league :-( |
Pioneers have a microfuse inside which are known for blowing ridiculously easy.
most of them that are fused have a small fuse on the outside on the back where the connector is.
The player wasn't blown......a pop and smoke on wire....but player just fine
I was just having wiring issues......and my yellow/red were backwards, so my player works...and my memory works ok Paul D aka my resident expert I got one for ya!! My amp pushes 240x2 RMS at 4ohm (bridged)....and thats what I neeed since my subs are 600w max and 300w RMS They are Dual Voice Coul 4ohm......wired in series therefore....the speakers are 8ohms ......How can I achieve a 4 ohm load Someone mentioned twisting the wires together, then bridging the amp What load will my amp see then? |
you're subs are 8 ohm OR 2 ohm. The best way is a parallel/seiries combo. I was going to try and explain it, but here is a diagram
http://akamaipix.crutchfield.com/ca/...4-ohm_mono.jpg |
yeah.....thing is.....there is a wall separating the subs
and I would have to drill holes to run all those extra wires from speaker-to-speaker thats why I was wondering....with (2) 2ohm or (2) 8ohm...twisting the wires together, would it double the load or halfen the load? |
that diagram is where the speaker coils are in series at the sub and the two subs are in parallel (I guess thi is what you are calling "twisting them together"). How are they wired right now ?
2 seperate boxes....wired in parallel = 2ohm load
+ and - wire running from each box twisting them together means....twist both + wires and both - wires together going to the amp that should create a 4 ohm load......it should double...2ohm+2ohm=4ohm Correct? |
ok, do the "wire twisting" for each sub, that will make each sub 2 ohms. There should be 2 wires coming out of each box. Take the + from one box and connect it the the - from the other box and tape that up. Connect the other + and - to the amp. That will be a 4 ohm load.
Twisting the wires as you call it is wiring them in parallel, it doesn't add impedance - it cuts them in half (for two speakers or voice coils). That's why you have to do parallel on one set of connections and series on the other set. parallel = both + tied together and both - tied together series = one + to amp, the - that goes with it tied the the other +, and the last - to the amo |
I don't know what I was thinking.....(or rather not thinking)
if you have the base knowledge and apply it....everything else is basic common sense!! all I had to do was THINK......parallel cut, then to counteract that, you series to double.... you are the 5-Star General...and will be receiving your medal shortly :-) CHEERS Hmm....im going to get no gain with this amp+speaker setup with series the subs will share the power, soo 240w/2=120 per speaker and my amp already pushes 120w at 2ohm stable through all 4 channels The only way I would get my full...is wire each voice coil independently to my amp 4 channels But w/e.....I knew the best option is a new amp, that's a no-brainer ohh well no love, no lost This was a nice refresher....that will help me later on on other installs |
