Old 01-29-2009, 04:33 PM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
this f@#& Ford
I have a 1992 ford f-150 4x4 5.0 it seams to be losing power and the truck backfires into the air box would this be a map sensor problem this thing is gutless now it is a standard shift and it lags after you shift
Old 01-29-2009, 07:29 PM
rhandwor rhandwor is offline
Re: this f@#& Ford
Use an ohm meter and check your wires look for appx. half scale. A small gap will cause a back fire when it jumps the gap.
Do a compression test on the engine a cracked spring or bent push rod will cause a back fire.
Check the timing a jumped chain will cause these types of problems.
Old 01-29-2009, 07:42 PM
Re: this f@#& Ford
opcorn:it does not back fire all the time only when it really cold out and when you run it out of gas
Old 01-29-2009, 08:07 PM
Re: this f@#& Ford
any help would be appreciated
Old 01-29-2009, 08:20 PM
Re: this f@#& Ford
When you run it out of gas do you mean you have to walk back and get a can or do you mean something else.
Old 01-29-2009, 08:29 PM
Re: this f@#& Ford
walk back for a can like in e for empty
i usually have one with me
Old 01-29-2009, 08:44 PM
Re: this f@#& Ford
Running empty allows you to pick up dirt in the bottom of the tank. Check the filter if its hard to blow through its probably plugged. Try cleaning the idle air control valve. I think the parts store sells fluid to clean the air flow meter.
Try unplugging it and see what happens.
Old 01-30-2009, 06:55 AM
fireplow fireplow is offline
Re: this f@#& Ford
I once had a 92 that was gutless after going thru a rebuild on the engine I found the hamonic balancer had spun. I reajusted the timing and it came back to life. changed out the balancer and it ran great. After talking to a friend of mine about the find he said that it was uncommon to find that. He has been working on veh. for better that 30 years. He had seen it on the smaller engines but not so much on the 5.0 hope this helps
Old 01-30-2009, 10:31 AM
Re: this f@#& Ford
thanks for the info
the truck seams to not have power going uphill
Old 02-10-2009, 11:59 AM
Re: this f@#& Ford
it was the map sensor
