Go Back   Automotive Forums Car Chat > Renault > Laguna/Laguna II
Old 01-29-2009, 04:10 PM
ashjonwil ashjonwil is offline
dci blue smoke when pulling away
Can anyone help.... i have a 52 plate 120 dci starts,drive nice but when i pull away it smokes bad when cruising all is ok but when i slow the accelerate again more smoke....been told its the turbo but i still have lots of power and pulls like a good un....???? anyone
Old 03-21-2009, 09:24 PM
notmeatall2 notmeatall2 is offline
Re: dci blue smoke when pulling away
Hi m8
Before I start i want to make it clear that i am not a mechanic. I am a only a "Hobbiest" car repairer due to the fact that i cannot trust garages as they have tried to rip me off several times.
You say it is blue smoke.
This sounds like oil burning to me.
Unburned diesel tends to be white or grey smoke.
Does it use a lot of oil??
Could be many causes.
Turbo Oil seals. ( I favour this cause it only seems to happen under acceleration)
Head Gasket.
Valves seats worn or valve stems bent.
Piston Rings.
+ many more.
One quick check u can do is look for signs of water in the oil or oil in the water. take off the oil filler cap and see if it has "Mayonaise" on it. also on the dipstick.
Old 12-18-2009, 09:16 AM
valeri_s_k valeri_s_k is offline
Blue smoke when slowing usually means oil is drawn in through valve seats and burned...
