Old 01-29-2009, 01:14 PM
bowtieboy12 bowtieboy12 is offline
NEED SERIOUS HELP NOW!!!! please!
GA_googleFillSlot("Forums_ROS_300x250_noad");2004 4.3L 4wd. i just installed a stereo system and now the thing is not right. it starts but slow and low rpms then builds up. it wont shut off with the key, just keeps running. when you put it into gear, it dies out. wtf!?!?! i ran a wire through the firewall next to where the main harness comes through, ands then through the boot under the hood. my only guess is that i hit some wires somehow??? i was extra careful not to. please someone help, im stranded and got no idea what to do?!?!?! i appreciate any suggestions and input, thanks guys.
Old 01-31-2009, 11:00 AM
bearcat329 bearcat329 is offline
Wink Re: NEED SERIOUS HELP NOW!!!! please!
try disconnecting the new wire, then try disconnecting the + battery cable, try to get the ECM to reset if that doesn't work, then check that harness very carefully, as you may have rubbed a wire bare, if you did, it'll probably be against some metal, grounding it out, put some electrical tape around it
hth
Rick, Ore
