Old 01-29-2009, 02:11 PM
bowtieboy12 bowtieboy12 is offline
NEED SERIOUS HELP NOW!!!! please!
2004 4.3L 4wd. i just installed a stereo system and now the thing is not right. it starts but slow and low rpms then builds up. it wont shut off with the key, just keeps running. when you put it into gear, it dies out. wtf!?!?! i ran a wire through the firewall next to where the main harness comes through, ands then through the boot under the hood. my only guess is that i hit some wires somehow??? i was extra careful not to. please someone help, im stranded and got no idea what to do?!?!?! i appreciate any suggestions and input, thanks guys.
Old 01-30-2009, 07:21 PM
j cAT j cAT is offline
Re: NEED SERIOUS HELP NOW!!!! please!
in cases like this it is best to carefully remove your stereo system and return it to original..as you do this take care and see if you can find what you damaged....
running wires thru the firewall can be a problem if you don't know what your doing....
a long time ago my first car i drilled directly into my voltage regulator resistor...in those days you had generators ......
Old 01-30-2009, 11:33 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Could be a short in the ignition switch. What wire did you run through the firewall? I don't recall having to do that for a stereo, even for the radio memory. There are wiring harnesses you can buy to connect to the factory GM radio, but can't be sure for your app. Where did you take your other power taps from?
I'd agree with JCat, back yourself out of the install a little at a time...chances are you forgot a connector or as you said could have nicked a wire in the process. Disconnect the rogue wire first, then the radio power, antenna, etc, and look for any stray damage, melted wire, or other oddity. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
