Old 01-29-2009, 11:50 AM
chevy393's Avatar
chevy393 chevy393 is offline
headers are headers right?
well pretty much iam looking at getting a set of headers for my 2000 chevy 1500 5.3L, i dont have a lot of money to spare and i was looing at some summitracing brand headers that are $150, my thoughts are its just a bunch of metal tubing nothing really to go wrong headers are headers (minus long tube, shortys, etc, etc and tuning but) , do u guys think there not worth getting and i should wait and get a name brand set or what? thanks
this is them BTW
http://store.summitracing.com/partde...5&autoview=sku
Old 01-30-2009, 11:46 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: headers are headers right?
I've seen differences of 10-20 hp between different styles. Some are simple collector straight style headers and some are "equal-length" meaning the tube length from each cylinder's exhaust port to the collector (where all the tubes converge) is the same. The equal-length is supposed to reduce back-pressure by allowing the exhaust pulses to reach the collector at different times according to the firing order. In the simple straight ones, the pulses combine in the header, resulting in pressure waves that can travel back and forth inside, creating back-pressure.
Other considerations are how the tubing is bent, what the interior surface finish is, and how the exterior is coated to retain heat. Mandrel bent tubing is best since the bending process doesn't cause ripples or reduce the cross-sectional area of the tube. Most tubing used is seamless, but attention to welding and how the collector is formed creates the easiest path for the gases to flow. Finally, headers that are finished with ceramic or other heat retentive coating will offer better performance than uncoated...they'll probably hold up better to the heat as well.
Looking at the ones you are checking out look typical for a cheap set. Tubing is mandrel bent, but is made up of seprately bent pieces welded together. Better sets will have all mandrel bent and no welds. Plus, the regular paint finish won't look good for long. It's bound to flake off and the steel turn rusty from the heat. The collector is simple too, just all four pipes leading to a flat round plate with four holes in it. Not a very smooth transition of gas flow there. Just my 2 cents....
Which header is best? Ask that here and you'll probably get a thousand different answers because few of us (excluding me) have actually tried more than one set on the same engine...it's just too darned expensive to experiment since you can't try before you buy. But I'll say in general, you'll get what you pay for. Those that have had more engineering and testing work done are those that cost more, but the pay off is easier install, more tech support, and greater guarantee in real hp gains because they've done the guesswork for you.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-30-2009, 11:40 PM
chevy393's Avatar
yea it has, thank you, some i was looking at as a back up were a pair of edelbrock or pacesetter cant remember that i was going to get if it was a big diff, and i think one of them were ceramic, thanks ill probably get one of those i guese, a bit more $$ but i dont wanna waste it on crap
Old 01-31-2009, 09:43 PM
ktisdale_2 ktisdale_2 is offline
also be sure to get one with a thick flange. this helps reduce the risk of it warping due to high heat and leading to exhaust leaks.
Keep 'em spinnin,
HiSpeed
'93 GMC Sierra Xtended Cab
350 ci crate engine., 2" Swirl Torque carb spacer, K&N Cold Air Intake, Hedman Headers, Underdrive Pulleys, No-cat 3" true dual exhaust, Dual DeltaFlow 40 Series Flowmaster Mufflers, B&M Shift Plus Kit, SuperChip, Dual 12" Memphis M-Class subs in Custom under-seat downfiring box, '98 Chevy All Chrome grille w/ Billet Bowtie, Clear corners, Rhino Spray-in bedliner.
'97 Grand Am 2. something.
All stock, gas saver....
Old 01-31-2009, 09:52 PM
chevy393's Avatar
ight thanks
