Old 01-29-2009, 10:31 AM
darkcherrymetallic darkcherrymetallic is offline
Where to lube?
Hello,
I did a thread search on this forum to see if there are any old threads on how and where to lube a car, but without success. I've been changing my engine oil for several years now, and it occurred to me that maybe I ought to also lubricate the car. I have a 2002 superhcharged grandprix gtp. If anyone has any information, that would be much appreciated?
Thanks
Old 01-29-2009, 03:32 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Where to lube?
There arent any grease zircs unless you have replaced parts. I replaced my tie rod ends which I grease at every oil change.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-29-2009, 05:32 PM
CrazyHorst CrazyHorst is offline
Re: Where to lube?
The W-car chassis (speaking here of 97 on up) doesn't have a greasable chassis like the old body-on-frame cars (if this is what you are after). Even the steering tie-rod-ends are sealed.
My old pickup trucks all the way up to the GMT800 chassis have zerks for the lower control "A" arms (with exception of the torsion-bar suspension) and the entire steering link system. Of course they are still the classic body-on-frame design.
You might want to change the gear oil in the supercharger though...look in the tech-tip forum.
If you want to get wacky you can start doing automatic transmission fluid changes.....
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 01-29-2009, 09:12 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Where to lube?
Same here, one tie rod end has a zerk, however the passenger side does not, so I grease the drivers side when I change the oil.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 01-30-2009, 07:49 PM
Re: Where to lube?
Thanks everyone for the information. It was really helpful.
