Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-24-2009, 09:30 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
Re: Installing new spark plugs in '03 Montana
I am going from underneath and can get to all three plugs. My current problem is that I can't get the old plugs loose. Any tricks or advice? Thanks
Old 01-25-2009, 01:41 PM
newfiejeff newfiejeff is offline
Talking Re: Installing new spark plugs in '03 Montana
See my post on the bottom. If you need more instructions please email me at [email protected]
Jeff
Old 01-25-2009, 03:10 PM
wafrederick wafrederick is offline
Banned
You can get them from the top,unbolt the coilpack and move the engine forward.
Old 01-27-2009, 11:13 PM
rockwood84 rockwood84 is offline
you have to bump the ratchet handle to get the plug loose. the plugs are easier if the engine is cold. as a warm engine makes the plugs harder to loosen.and a swivel makes it a lot harder to control the ratchet. once you have the plugs loose switch to a short handled ratchet which will give you more room to turn the ratchet.
Old 01-31-2009, 11:20 AM
Re: Issue installing new plugs in '03
Ok, I got to them from underneath. Can't image it could be easier to go from the top. Used a 4" extension. I had access to a pit that I could park the van over, made the job much easier. Finished in 45 minutes. Thanks for the help and advice.
