Old 01-28-2009, 10:16 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Never Seen This Before. How Would You Tackle It?
Tried to go out riding and started fine. was warming it up and idling around. started to get on the throttle and i heard a soft pop and would run like 1 cylinder was firing. did a compression test. 30psi clutch side and 130psi muffler side. my question there are pretty damn deep groves worn into the sleeve. what would you do? re-sleeve and new pistons/rings? let me know. thanks! otherwise its been a great sled. I got under it the other day to shoot the grease fittings everything took the way it was supposed to. track is in great shape. I would like to fix it enough to get me through the season. funny thing was tho I went riding the weekend before and was WOT most of the ride. I was on a empty farm on packed powder and it was running amazing. not sure what to think here...
Old 01-28-2009, 10:53 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Never Seen This Before. How Would You Tackle It?
Ew....rebuild time.
Had similar carnage on an old blaster. Had a fresh rebuild. Started running like shit and knocking. Pulled it apart. Turned out that the piston/rod pin (not sure the technical term but its the cylinder shaped piece that holds the piston to the rod) was sliding out of the side of the piston and hitting the cylinder walls and ports. The reason it did it was because the guy that build it didnt put the clip on one side of the piston, allowing the pin to slide out the other side.
But in your situation, considering the position of the scars in relation to the rod, doesnt look like you have the same problem as we did.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-28-2009, 10:57 PM
steviek's Avatar
steviek steviek is offline
not good
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-29-2009, 01:00 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I had a similar problem on my 600SP last year, tuned it a bit lean and burnt a part of one of the piston rings and grooved the sleeve. Fortunately, I was able to have it honed out and it was good to rock, but my grooves were not NEARLY as deep or long as yours. I would just re-sleeve just to be safe.
What kind of sled?
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2009, 09:52 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I think its a bike Garrett.
Resleeve the shit, or get a new block. Either way thats not something that will buff out.
VG, I believe you are talking about the wrist pin.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-29-2009, 11:54 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Good job Dustin.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-29-2009, 01:09 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Originally Posted by david-b
Good job Dustin.
Comprehensive reading anybody?
**EDIT**
I just noticed your tagline Dave. That's great...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-29-2009, 02:01 PM
david-b's Avatar
Dave is THAT guy
Reading is Fundamental
Just spreading the good word.
75 Monte Carlo
Old 01-29-2009, 03:09 PM
steviek's Avatar
hahah how good was it?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 01-29-2009, 04:49 PM
david-b's Avatar
Dave is THAT guy
Left me nauseous and smelling like Vagisil Medicated Wipes.
75 Monte Carlo
Old 01-29-2009, 05:55 PM
Thor06's Avatar
Jizzed In My Pants
Oops.
Atleast you didn't glue your hand to your leg right before.
Old 01-29-2009, 11:04 PM
Yup. Like 10 mins after I posted, I remembered that that was what it was called, but I was too lazy to fix it.
Caleb
vanilla gorilla
Old 01-29-2009, 11:14 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
are you talking about the wrist pin?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 01-30-2009, 06:46 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yes he was.. Thor has already pointed that out.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
