Old 01-28-2009, 08:53 PM
wbroome wbroome is offline
7.4L long crank time when sit for a few minutes
1999 7.4L has long crank time after sitting for several minutes new fuel pump installed no codes
Old 01-28-2009, 10:17 PM
tempfixit tempfixit is offline
Re: 7.4L long crank time when sit for a few minutes
What brand fuel pump installed?
Have you checked the fuel pressure for leak down? Restrict the return flow hose to test if it is the pump or fuel pressure regulator. Do a search for fuel pressure test by MT-2500, exellent procedure to reference too.
Did it have the same problem before new pump?
Old 02-01-2009, 09:16 AM
bracketshark bracketshark is offline
I agree do the fuel pressure test. We just changed out a 99 model 454 because the fuel pressure regulator failed and filled the motor with gas, locking the engine. The regulator is external on the big blocks, much easier to acess than the small blocks. I have the 454 vortec core that was replaced by a GM long block. If anyone needs one, it ran well with 40-60 psi oil pressure before being replaced. Owner wanted a "new" motor.
Old 02-02-2009, 09:57 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Yep, sounds like fuel pressure regulator................
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
