Old 01-28-2009, 05:15 PM
silentdarkness1317 silentdarkness1317 is offline
Send a message via AIM to silentdarkness1317
just a quick 91 civic question (edited for douche)
i have a 91 4-door civic and i wuz curious if 91 crx front end parts are compatible. i just like some crx front ends, that ive seen, a little more than civics. thanks for any replies.
Old 01-30-2009, 10:07 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: just a quick ef question
Basically - no.
Everything except the headlights and corner lenses won't fit quite right unless you swap (convert) the whole front end.
That means everything from the firewall forward, basically. The inner fenders aren't even the same, I don't think.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 01-31-2009, 02:40 AM
GTA's Avatar
GTA GTA is offline
Whee..
corner lense are different actually. if you swap everything over fenders, bumper, hood, lights etc, it should fit.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 01-31-2009, 11:00 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
I am 90% sure the hoods are the same.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 01-31-2009, 09:13 PM
Can someone please tell me what the difference in the corner lenses is? I am running CRX lenses on my 4 door.. and have been since I got it... and the previous 4door had the same lenses in it... I see absolutely no problem.
The headlights and brackets fit fine, the corner lenses fit fine - from the same split-generation for both. (If you use 90-91 heads, you have to use 90-91 corners too, same for 88-89)
Bumper lenses are the same, except they're also split-generation.
The hoods are DIFFERENT. The CR-X and Hatch have interchangeable hoods, the Sedan's is about 2 inches longer.
According to Rockauto.com, the part number for the 88-89 and the 90-91 corner lenses is cross referenced to Sedans and Hatches... they don't have a PN for CRX's for the same part, and the Wagon is different (somehow).
Oh - and just to be a douche, you almost certainly don't own an EF.
Old 01-31-2009, 10:48 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Another big difference is the radiator support. The sedans is bigger than the hatch.
Old 02-03-2009, 05:31 PM
i thot 91 civics were apart of the ef "group"(if i can get away with calllin it that) due to the fact that im not completely honda literate but i am tryin. now if you have some mustang questions id be glad to help but im tryin somethin new and im fartin around with hondas for a little while.
thanks everyone for the help.
Old 02-03-2009, 07:33 PM
Yeah, you can call it that if you want... I was just being anal about the fact that the designation goes based on your actual Chassis code... and EF is the JDM chassis code, while ED is the USDM code for all Civic/CRX models from 88-91.
Some people care, some don't. I happen to abhor incorrect terminology, and strive to educate those who use it. If you don't really care, meh, it's not the end of the world.
Welcome to the Honda scene, enjoy your stay, and while you're here, the best tip I can give you is to try to keep your car's "soul" intact. If you don't know what that means yet, you'll figure it out later, after you get into it a bit more.
Old 02-04-2009, 06:36 PM
[quote=Dr0pZ0n3]best tip I can give you is to try to keep your car's "soul" intact. quote]
i believe youre referring to the honda cancer that can seem like a small tiny bit of surface rust but end up bein 20 hours worth of welding and bondo and yada yada yada. if you mean the motor however i helped a buddy of mine put his b16a together which is what im thinkin about droppin in my civic. not sure yet. i bought it with a body kit on it but since its a 4 door i cant do the front end conversion i wanted so i guess im stuck with the body kit. well i gotta get off here to go play dodge ball but i'll probly get on tm to look for any replies. any suggestions will be considered on what i should do with it. thanks for the info.
Old 02-05-2009, 12:56 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
hahaha...I caused someone else to correct the EF/ED terminology.
EF is the common term used for our cars because people either don't know their real chassis codes or just don't use ED because they don't want to explain the difference to others.
Tony
91 Civic Sedan DX - Stock 287k Miles
