Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-28-2009, 09:06 AM
GDan GDan is offline
2002 sport trac 4 wheel drive stop working
My four wheel drive just stopped working. No dash light and the switch seems like it is functioning...but nothing? Any suggestions anyone?
Old 01-28-2009, 12:04 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 sport trac 4 wheel drive stop working
Welcome to the forum!
Have you tried searching the forum for symptoms similar to yours? There have been quite a few posts related to the shift motor on the transfer case. You might try keywords "transfter case."
-Rod
Old 02-11-2009, 02:34 AM
IBARoofer IBARoofer is offline
HI. My neighbor has a 2001 Explorer that had the 4x4 stop working. His will work if he pulls the #35 fuse for a few moments and the puts it back in. It will then go into 4x4 via the switch.
It will last 1 or 2 days like this before it has to be done again.
It also seems to need that to take it out of 4.
I am searching the forum to find the cure and I will get back to you if its the same problem you have and I find it.
Good luck.
