Old 01-27-2009, 10:52 PM
5150Watts 5150Watts is offline
02 8.1L crankshaft problem?
I recently upgrade my 97 to a 02 2500HD with the 8.1L. I have discovered that the front crankshaft seal is leaking oil. I took it too a shop and they told me that the crankshaft has too much end play, and the seal can't be fixed without fixing this. That is a major engine overhaul. My question is, is there really a way to determine this with out tearing the engine down? Also, is this a common thing? It only has 77,000 miles on it. This surprises me for the mileage. So, any recommendations on what i should do?
Old 01-28-2009, 09:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 02 8.1L crankshaft problem?
Sounds strange.
Is the end play over specs?
Or how much end play doe it have?
Has a new seal been installed?
MT
Old 01-28-2009, 10:40 AM
kahjdh's Avatar
kahjdh kahjdh is offline
usually you would get this with manual transmissions. You dont need a whole overhaul but maybe a new thrust bearing or bearing set.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 01-28-2009, 05:08 PM
I do not know if it is out of spec. They only told me they noticed play when looked at the front seal. If it is a thrust bearing, can that be done from underneath through the pan, or pull the motor?
Old 01-28-2009, 05:18 PM
MT-2500's Avatar
AF - Advisor
There is not enough miles on it to be bad yet.
Check it out real close.
I would get a second opinion/check on it.
End play should not wipe out the seal.
And if that much side play the engine would be knocking.
I would put a new seal in it and check the crank pulley snout.
They make a ready sleeve for a worn crank pulley snout.
Good Luck
MT
Old 01-28-2009, 06:57 PM
I get a knock in morning for about a min then it goes away. I do get a flutter sound when i accelerate but I think the exhaust manifold is leaking a little. My 97 made the same noise. Other then that it sounds clean.
Old 01-28-2009, 08:27 PM
777stickman 777stickman is offline
Not sure about your '02 8.1, but I thought I had a front seal leak on my '98 7.4. Turned out to be the o-ring on the CKP (Crank Position Sensor).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-28-2009, 09:34 PM
It is the seal where the crank pulley is. At first, we thought it was the oil cooler lines.
Old 01-30-2009, 06:53 PM
It looks like the main seal is leaking as well. Guess it must be the thrust bearing.
Old 01-30-2009, 07:03 PM
MT-2500's Avatar
AF - Advisor
Check end play before throwing thrust bearing at it.
MT
