Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-27-2009, 06:49 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
Oxygen Sensor - Bank One Sensor One
Service Engine Soon light On. Had the codes read. Said Oxygen Sensor, Bank One Sensor One was sending no data. Where is this located?
Thanks
Old 01-27-2009, 09:59 PM
discnik discnik is offline
Re: Oxygen Sensor - Bank One Sensor One
Please check your Private Messages. Hope it helps.
Old 01-28-2009, 11:59 AM
rkvons's Avatar
rkvons rkvons is offline
How do I check his private messages, so that I, too, understand?
Old 02-04-2009, 06:57 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: Oxygen Sensor - Bank One Sensor One
As far as I know you can only check your own private messages, not someone else’s.
From what I have read in this forum, there are two O2 sensors. One near the catalytic converter and one on the right bank exhaust manifold at the rear of the engine room (near the firewall).
You can’t see the first one (referred to as bank one, sensor one) unless you come up from underneath. I saw it when I replaced my plugs in late fall. It could be that the wiring harness has become disconnected. Before you replace it, check the wiring to make sure everything is plugged in to the sensor.
Also, the more I read, it sounds like this O2 sensor is only good for about 80,000 miles and should be replaced as part of regular PM.
You may have to roll the engine forward and remove the coil pack to see it, but it’s there, along with a smattering of wiring that can get tangled, or even burned by the hot exhaust if moved during a spark plug change.
Old 02-04-2009, 07:20 PM
Scrapper Scrapper is offline
AF Premium User
another thing is go buy them before you take the 0-2's out that will show you what your looking for there in front of the catalic converters and they unscrew like a spark plug. also rent the special socket that take's them out if getting from autozone or just buy one there i think there about 8 bucks or less you'll need it in futcher as it will fit other cars you buy also..good luck..
