Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 03-23-2003, 06:10 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
pearl paint
what is pearl paint how does it differ from normal paint?
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 03-23-2003, 06:35 PM
zippeay zippeay is offline
Pearl is a special addative thats added to paints from the factory or you can actual buy different colors of pearls and add them to any paint. Its kinda hard to explane, you've seen the new Cadillac Excalade's haven't you, well the white ones are pearl white but there are tons of different colors of pearls not just white. Thats the best way I can explane it.
Old 03-23-2003, 06:36 PM
Jetts's Avatar
ive seen pearl paint just not sure really what it is
cause when i get done with the all the body work on my 4th gen when i get one im going to paint it black with blue pearl ghost flames
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 03-23-2003, 06:45 PM
Well, are you doing this yourself? I haven't really messed with pearls too much but I'm pretty sure you can't just spray pearl, you have to mix it with a base. Plus you can't paint blue over black, you can never paint a lighter color over a darker color cause it won't show up. You'll have to paint the car black, tape off your flames and but a white or silver base down first then go over it with the blue pearl "mixed with the base"
Old 03-23-2003, 07:30 PM
Jetts's Avatar
oh hell no i aint doing it myself, having it profesionally done and you do the flames first then you do the black over
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 03-23-2003, 09:45 PM
Duatone Duatone is offline
Pearls are simple. basically, its just a reflection color. like you can look at a car and it looks white, but if you look at it at a certain angle, (depending on how much pearl is on it), you then see a (place color here) hue to the white. some people like A LOT of pearl so you can see it right off the bat. im going to do a light platinum peal on my car when i re-paint it. though im mixing my pearl with a clearcoat, then another coat of regualy clear over that. this is the way i was taught to spray it. though if you do TO MUCH pearl, then it will just mirror, thus that all you'll see is the pearl. also, there is this new product that just recently came out that helps suspend the pearl when you shoot it, kinda like when you lay down the basecoat, it dries just a fast as that, so it has enough time to flow, then dry, and not flow out of control to where it might sag or run or model. just depends on your method of painting. also, you can do blue over black, it'll help with the ghost flames. most ghost flames you see are either the same color as the base, or pretty damn close, cause you want them somewhat there...but are they? its all relatively easy.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 03-24-2003, 01:22 PM
Jetts's Avatar
thx for the info
i knew the paint scheme is possible, i just really didnt know what pearl actually was
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 03-25-2003, 12:41 PM
95civicman 95civicman is offline
pearla acually isn't mixed into the base coat paint of the car. (that would be a flake) it's mixed in (or already in) the clear coat. and you don't really need to put a lighter color on the car to make ghost flames. you can just put on the pearl and it will show up only when you get at the right angle. add a lighter color to see it all the time.
:edit: just read all of duatones post and he got most of it covered
zc powered 89 CRX SI with some more stuff.
Old 03-25-2003, 04:03 PM
Ok I made a mistake about not painting lighter colors on darker colors sort of. You can do it but you won't see it very well, but it will give you the ghost look your looking for. As far as not having pearls in base is a BS, there are a ton of bases with pearl in them, you can use pearls in base's or add it to the clear, but as far as I know you can't just paint straight pearl. There's nothing to make is stick, its just like adding metal flake pretty much, you can buy paints with flake in them or add them to the clear both ways will work. Good luck with the paint
Old 03-26-2003, 06:33 AM
wurd my mistake i was sorta not right the other day and wasn't really paying attention to what i say but it had the point i wantd to get across in
Old 04-01-2003, 04:26 PM
GhettoLegs's Avatar
GhettoLegs GhettoLegs is offline
Send a message via AIM to GhettoLegs Send a message via Yahoo to GhettoLegs
This is an interesting topic because I am almost done w/ my car... all I need to do now is repaint the car before I go back to school. I was thinking about keeping the stock color... kinda. See... I want to go w/ a color like Charcoal Flint Metallic.... but I want to add platinum pearl over it so it shines back silver in the sunlight. I don't know how well this will turn out... anybody seen a color like this before? I'm curious because the charcoal color looks almost black... except for where the sun shines back at you... looks kinda gray/silver. Do you think it will turn out good or should I just not bother w/ the pearl? I would like to add the pearl... but if it doesn't show, what's the point? Feel me?
Old 04-01-2003, 04:28 PM
Jetts's Avatar
i dont know i still dont really understand what pearl paint does, or what is the diff. between normal and pearl
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 04-01-2003, 04:38 PM
GhettoLegs's Avatar
Okay... check it out. Pearl paint is a transluscent paint that you can see through. Say you want to have a white car w/ blue pearl. You spray the car white... then you spray the blue pearl over it. The pearl paint is see through... so you will basically see a white car. However... the pearl paint is visible when light reflects off of it. So you will see a white car... but in certain places... you will see a blue color. Do you understand? Let me show you some pictures of my car and my friends car to help.
Here is my car:
Notice how my car looks black... but on the rear quarter panel and C-pillar where the sun shines off of it, it looks more silver colored? That's an example of what pearl does.
I have to go but I will show you a picture of my friends S14 Silvia later... it is yellow w/ gold pearl.
Old 04-01-2003, 04:41 PM
Jetts's Avatar
k i get it now
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
