Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-27-2009, 11:07 AM
82CapriceClassic's Avatar
82CapriceClassic 82CapriceClassic is offline
Would A Bad Ball Joint Cause
your car to make clunking noises? and how important is it to get fixed? like do i need to get it fixed ASAP?
i keep hearing clunking noises in the back right hand side of my car...i went to the mechanic to see if it had anything with the fact that i just had new shocks installed...told me i had a broken hanger on my flowmasters..took it to the muffler shop..they replaced both of my hangers and put on a new collector gasket...still have the clunking noise and its worrying me...they told me its possible it could be a bad ball joint
nobody is telling me WHAT it is..only what it MIGHT be
Old 01-27-2009, 11:29 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Would A Bad Ball Joint Cause
Time to find another repair shop.
The mechanic should take your car for a test ride to determine what is going on.
Anyone can guess, sounds like these guys are lazy or do not want your business.
It does sound like your exhaust might be hitting somewhere, very easy to determine.
Front end noise would probably be coming from, you guessed it, the front of the car..
Good luck
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 01-27-2009, 12:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You have an axle back there, so no ball joints are used. I'd definitely suspect the shock bushings or the bolts. They may not be correct diameter, leading to endplay. Or they aren't tighened to spec. Or shock cylinders are a different diameter than the originals so are rubbing against a sway bar. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-27-2009, 12:55 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Agreed with the above. It can't hurt to have the ball joints checked just due to what can happen should one fail. If they are indeed clunking, their time is marked.
At a low speed, the tire can 'pretzel inward' or the car can dig a trench in the asphalt, depending on whether it's the upper or lower respectively. An at-speed failure can be catastrophic.
You could have a worn out control arm bushing on the differential somewhere and this could be causing the clunk.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-27-2009, 04:05 PM
Problem Solved...took It To Meineke..it Was My Uv Joints...got Them Both Replaced For $215...
j cAT j cAT is offline
when your vehicle is put on a lift the frame is lifted not the wheels this is a good reason why they can't find the problem..
which all gets to incompetent repairers....this is a widespread problem getting the skilled auto repairer to repair your vehicle properly..
one way to force this is when they guess tell them you want it in writting that this will stop this noise or its free...
Old 01-27-2009, 04:42 PM
hopefully this will stop the clunking...normally you will get vibration and a large clunk when changing from park to drive/reverse...as well as squeeking sounds....when these fail....
when you get your oil changed don't forget to have them grease those drive shaft U joints,,,the new ones will have grease fittings...
Old 01-28-2009, 02:06 PM
So They Wont Have To Grease The New Ones I Had Put On Yesterday Right?
And I Would Hear A Clunk Also When Switching Gears..but It Would Only Happen When Im On A Hill Or Any Type Of Incline
Old 01-28-2009, 02:34 PM
yes the new U joints need to be greased at oil change time...then they will last forever...
if you are parked on a hill and put into drive from park you will hear a clunk....but if you are level ground you should not hear that noise...
if your idle is too high this will cause this noise also ..idle should be 650-700rpm....
when driving in drive you should not hear clunking are you still hearing the clunk sounds when driving?
Old 01-28-2009, 08:31 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Speaking of that clunking..if its really cold and my car hasn't warmed up it'll be revving so high that when i shift (very rarely however) i hear the gears scrape as it dumps into drive or reverse...not a nice sound to hear
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-29-2009, 12:15 AM
oh yea it only clunks on an incline..however i do think my idle is a little high and my carb is off bc my car is INHALING gas..but im going to get that fixed in the AM...not to mention i need to replace some spark plugs and get a tune up lol...just so busy with school dont have time to do everything on time like im supposed to
Old 01-29-2009, 07:45 PM
a high idle will damage the U joints as well as the transmission....you may also find that the brakes wear at a faster rate...
Old 01-30-2009, 09:18 AM
ok i got my carb fixed this AM...the guy i take my car to just stuck some type of tool into the side of the carb and twisted..so im guessing he took my idle down
but the last time my idle was high and i watched the person fix the carb it seemed like it took longer for the fix to happen..and this fix happened in about 10 mins
jcat where are you located? u know so much about cars seems like lol
Old 01-30-2009, 11:12 AM
the reason I have good knowledge about this era of vehicles is because in 1983 I bought one new..then 17yrs and 380,000mi later sold it for 1700.oo...not bad..I never had any work done by the pro's...since I have a mechanical background and electrical/electronic training/schools..
I still have a 1984 305 chev with the carb same as yours,, so its still working and needs attention as most carbs are problematic...you will find it very difficult to get this repaired because fewer mechanics are skilled in carb's ..also the adjustments are critical if you want it to operate correctly..
having the spec's for your vehicle to adjust this correctly would be a surprise...
I would think that a young woman like you should have a newer vehicle, and this then would make it easier to get repairs done...unless you wanna be a mechanic..I have worked will several females that did choose this type work...
In massachusetts where I live these cars are rare as the winter destroys them...most owners use them only when the salt/chemicals for snow are long gone...they do give a good ride quality and are stronger than the new vehicles, but when gas goes to 4.oo+++ /gal you gotta have a more effecient vehicle for daily use, and reliablity....
Old 01-30-2009, 09:49 PM
i just have a thing for the older bodied style cars...and the material and quality they were made with..my car is like a tank lol..says alot when your car can last 20+ yrs...
not to mention the parts are cheaper...and i have no problem with getting my hands dirty at all..i like to know what exactly is going on just in case it happens again...
