Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-27-2009, 07:10 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
engine swap?
I'm really hesitant to do any major engine work on my caprice and its low miles. But the idea came to mind...what if i swapped out for something like the amazing 302? All i know is that was or in my opinion the greatest of the smaller small blocks. I don't even know if it would "fit" so to say but you can make anything work if you really wanted to. To me the idea of a sleeper caprice is inspiring.
Then again i mean my "anemic" 305 is in perfect working condition and it makes me cringe to think of ripping it out or doing some serious surgery. Maybe i'll have to find another caprice to do this with.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-27-2009, 12:51 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: engine swap?
302? Are you kidding?
Those were only made for 3 years in the late 1960s, and while you can make one yourself (using a 350 block), the money you spend will not be worth the gains you get. In other words, a 302 will perform similarly to a 305 in your car - the 302 was a high RPM motor and you will never see that sort of use out of it in your Caprice.
You're better off with that 350 intact in place of the 305 if you really want to go there.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-27-2009, 05:34 PM
bhw33191's Avatar
Re: engine swap?
Ok lol your right. I'm young so i don't have much knowledge about these older engines. I guess if i was looking for any kind of power gain (using my stock block) i should just stick to what you said about using a different cam. But hey all of this talk is still a figment of my imagination at the moment.
Old 02-16-2009, 12:59 PM
NOVAZ27 NOVAZ27 is offline
Re: engine swap?
Put a chev small block "400" in that caprice. If you can find one. They are torque monsters. Around 285 foot pounds at low rpm. Couple that with a 700r4 and you should not have any bogging in overdrive. Fuel milage should be fair also.
ON THE 305. IF YOU INSTALL A NEW TIMING CHAIN USE ONE THAT ALLOWS YOU TO ADVANCE THE CAM 4 DEGRESS. THIS REALLY HELPS LOW END TORQUE ON THE 305 MOTOR. VERY MINIMAL LOSS AT HIGH RPM.
John in belton
novaz7
Old 02-16-2009, 01:29 PM
silicon212's Avatar
Confoundingly Lucid
Re: engine swap?
285 lb. ft. is weak for a 400, it's even weak for a 350. Most 350s can do 300-350 lb. ft and a 400 should do over 350 lb. ft.
Old 02-16-2009, 02:31 PM
Re: engine swap?
Sorry about that. Should have been "385" footpounds. I had a 76 impala brookwood station wagon with a 400 smog stocker. It was a wolf in sheep clothing for at least the first 1/16 mile. Not much on top end however. Wish i still had the car.
Old 02-16-2009, 06:05 PM
CD Smalley CD Smalley is offline
Re: engine swap?
You must remember these are big and heavy cars. Torque is what overcomes weight.
To really get torque, you need displacement.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-17-2009, 01:21 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: engine swap?
Try a 472 or 500ci caddy engine, 500ft lbs stock torque.
I have one in my garage that I pulled from my 71 coupe de ville , I wanted to put into my caprice but the smog police here in socal won't let me..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 02-19-2009, 01:40 AM
mike561 mike561 is offline
Re: engine swap?
I gotta say you still cant beat these small block chevy motors no matter what, this was quoted right from a wikipedia article "Chevrolet tested the small-block twice with no water and no oil at wide-open throttle. The first time it lasted an hour and 15 minutes and the second time it lasted two hours."
2006 Chevy Cobalt LS
Old 02-19-2009, 01:54 AM
silicon212's Avatar
Confoundingly Lucid
Re: engine swap?
Mine has over 300k miles on it and it's still as strong as ever.
It does use a bit more oil than it did, say, 150k miles ago, but still in a decent range.
Old 02-19-2009, 02:13 AM
Re: engine swap?
I used that Lucas oil in my last oil change, ever since then ive been barely losing any oil at all, though i know i still have a slight leak.
Old 02-19-2009, 11:52 PM
Re: engine swap?
I'd like to see any new engine up to the no oil and water experiment, engines nowadays probably wouldnt last more than 5 minutes
Old 02-20-2009, 02:58 PM
bhw33191's Avatar
Re: engine swap?
I see you have an edelbrock intake..do you notice any gain in performance?
Old 02-20-2009, 04:41 PM
Re: engine swap?
I did somewhat, the edelbrock i have was pretty much identical to the stock one though
