Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-26-2009, 08:59 PM
nova50000 nova50000 is offline
96 bronco runs at idle, but wont run under acceleration
ive got a 96 bronco 5.0 will run at idle but when i accelerate will be like i shut the key off. already changed the fuel filter,and have good fuel pressure. I can find no shorts in the ignition.
im thinking of a bad relay somewhere but am unsure. PLEASE HELP!!!!!!!
Old 01-27-2009, 12:15 AM
discnik discnik is offline
Re: 96 bronco runs at idle, but wont run under acceleration
Is this a fuel injected engine ?
When you said it dies when accelerating. Is that in gear or Park/Neutral ?
Is the idle rough or smooth ?
What were the fuel pressure readings ?
Old 01-27-2009, 09:05 PM
its the stock 5.0 fuel injected motor, now it will run for maybe 5 seconds at idle and then turn off like you turn the key off. even if i rev it up still within 5 seconds it will die. runs smooth the whole time. checked the coil, cap and rotor. all seems fine. im thinking maybe a crank sesor or something along those lines but i am still unsure.
Old 01-27-2009, 11:09 PM
Well here is a list of possibilities:
1. IAC valve, check & clean.
2. TFI module, (The module on the side of the distributor).
3. Stator pick-up coil. The distributor has to be removed in order to test the pick-up coil and TFI module.
4. Remote possibility MAF sensor. Testing the MAF requires either a scanner or Ford Break-Out box.
Can you hook up a fuel pressuree gage to it to see what the fuel pressure is doing when it dies ?
If you plan on testing the TFI module and stator let me know and I can PM you the test procedures.
Old 01-28-2009, 11:24 AM
turns out that it was the mass airflow sensor. turns out that a small piece of debris was caught in the small hole in the MAF and broke the contacts inside. i just unplugged it and it runs fine now. thanks for the help. greatly appreciated.
