Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 01-26-2009, 06:39 PM
jimb317 jimb317 is offline
Secondary air injection system fault code?
My check engine light is on. The code reads "secondary air injection system fault".
The scanner gave probable causes as:circuit relay defective or fuse open,
Check connector and wiring, AIR pump defective or hoses blocked.
Where do I find this? I will check the fuses first.
Old 01-26-2009, 07:24 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Secondary air injection system fault code?
the air pump is mounted to the fram crassmember right under the drivers seat. On of the first steps is to turn the key to the on position and listen for the pump to run. If it doesn't, whack the back of it. If it runs after whacking it replace it.
Old 01-27-2009, 10:06 AM
maxwedge maxwedge is offline
A990 racer
The air pump only runs occasionally on demand from the pcm, that test will not work, only if you use a bi-directional scanner to command it on. Check the fuse first, then the usuual problem is the check valve /solenoid gets moisture in it and can freeze or just fail.
Old 01-27-2009, 10:57 AM
Originally Posted by maxwedge
The air pump only runs occasionally on demand from the pcm, that test will not work, onlyi f you use a bi-directional scanner to command it on. Check the fuse first, then the usuual problem is the check valve /solenoid gets moisture in it and can freeze or just fail.
The fuse is good. Where is the check valve solenoid mounted?
Old 01-27-2009, 04:43 PM
A990 racer
In the hose from the air pump to the manifold.
Old 02-03-2009, 05:31 PM
If I remove the pump from the frame rail, and put 12vdc directly to it, should it run? Can I test it this way?
Old 02-04-2009, 04:05 PM
A990 racer
Yes. It must be grounded also.
Old 02-05-2009, 03:59 PM
there is a red and a brown wire at the harness. When I ground the unit which wires will I hook the power to?
Old 02-07-2009, 11:24 AM
A990 racer
Red should be power but to be sure check the wiring diagrams at autozone.com, repair guides.
Old 02-14-2009, 01:11 PM
The pump runs with power run directly to it. How do I check the check valve/solenoid mounted on the passenger side of the engine, that the hoses run too?
Old 02-15-2009, 01:32 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The AIR system on this vehicle runs at cold start. The PCM runs a couple tests on the system to verify proper operation and air flow.
The DTC # would be the most useful information and tell us what test failed.
The AIR pump should pump air to the solenoid mounted above the exhaust manifold during a cold start.
The solenoid valve should not have exhaust gas "blowing back" into it with the engine running (usually 60 seconds after cold start)
Post the DTC........
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 03-06-2009, 03:24 PM
would I have to go to the dealer to get the DTC#.
I went Autozone the read a code P0410.
