Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-26-2009, 06:30 PM
Scott Dog Scott Dog is offline
water in transfer case
I have a 1999 Wrangler sport, when i purchased it i checked all of the fluids and found that the fluid in the transfer case had water in it, so i flushed it and put new in, i checked the fluid 2 weeks later and it is even more watered down than before, please help
Old 01-27-2009, 10:08 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: water in transfer case
?? Puzzling. Unless it was submerged, a fluid change should hold.
Done any wheeling?
Not to be insulting, but do you have both plugs in the Tcase? How are you detecting the water; can you see it after draining, having it tested, or looking at the consistency?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-27-2009, 11:26 PM
hundahunta hundahunta is offline
inspect your transfer case vent hose...where is it located
Old 02-20-2009, 02:38 PM
i haven't done any wheeling other than a few muddy fields, and yes both plugs are in the transfer case, i first noticed the fluid was pink rather than red like it should be, when i inspected all of the fluids after buying the vehicle, so i drained the old fluid out and replaced it, the next week i checked the fluid and it was pink and watered down again.
i checked the vent hose and it was fine and the vent hole is located on top of the t- case and runs up onto the backside of the motor in the engine comp.
Old 02-20-2009, 10:37 PM
automatic or standard??? if automatic very puzzling, if standard, are you losing trans fluid also??
