Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-26-2009, 03:26 PM
kingsidewinder kingsidewinder is offline
1998 CR-V Tranny Glitches
I have a 1998 CR-V automatic with AWD. 125K-miles.
At times, the transmission will over-rev when changing gears between second and third....hot or cold. Yes....the tranny fluid is level. Is this a common problem, and what can I do to help or fix the issue?
Also....
At times (again), the tranny will not shift into 4th gear-overdrive. Normally, I drive for 10 minutes and the truck gets warm, then the overdrive engages at cruising speeds. 4th gear is as high as it will normally shift....and if it feels like it....overdrive will work a few times a week.
Any help / opinions would be appreciated! Thanks!!
Old 01-26-2009, 09:26 PM
jgr7 jgr7 is offline
Re: 1998 CR-V Tranny Glitches
Have you ever had your transmission serviced?
Old 01-26-2009, 11:42 PM
discnik discnik is offline
Unfortunately this sounds like something you should take to the Dealer to see if they can pull any tranny codes.
The only Service Bulletin I found was on "Harsh Shifting" or " No Shifting from 1 st" concerning the Linear Solenoid Assy.
Old 01-27-2009, 03:14 PM
I haven't done anything to the ATX besides having the tranny-oil changed about 4 years ago....shortly before a 3000-mile road trip. Also....there are no codes to pull....already tried that. Any other suggestions???
Old 01-28-2009, 07:22 AM
Have it serviced and see what happens.
Old 02-27-2009, 04:27 PM
For whatever reason, the tranny is shifting properly now. I reset the computer by disconnecting the battery for a couple minutes. I guess if I had it serviced to see what happens, I woulda been out a bunch of cash.
Old 02-27-2009, 06:45 PM
If you have never had it serviced you will be out a bunch of cash at some point in the future.
