Coolant leak
My 2000 Blazer has a significant coolant leak on the front drivers side of the engine. I add water, half a gallon runs out. Freeze plug? Intake gasket? Could the intake gasket leak so quickly? Help?
Re: Coolant leak
Welcome to AF.
You need to have a look and see where it is leaking. It may help to remove air compressor and bracket to see it real good. Check for intake leakage and water pump and freexe plug and kead gasket leakage. Let us know what you find or see.
Re: Coolant leak
Go to AutoZone and borrow the Radiator Pressure tester. It is a small hand held tire pump with a Radiator cap on it. When the engine is cool, and shut off, Attach the tester to the Radiator and pump it up to the pressure rating of the Radiator Cap. Your leak should be very obvious to see.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr. |
Re: Coolant leak
Not to be a stickler for details, but you mentioned pouring water in to replenish the coolant. Make sure you're using a 50/50 mix. I understand if you use water to find the leak (distilled or deionized), but make sure you bring it back to the proper ratio with full strength coolant.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
