Old 01-26-2009, 11:10 AM
Dave1081 Dave1081 is offline
92 LeSabre Custom - Third Brake Light
Does anyone know how to replace the third brake light - the one in the back window? Owners Guide refers to it as "High Level Stop Light" and references the replacement bulb number but offers no instructions for replacing it.
Reaching in from the trunk, I feel a plastic wired "plug" that goes into the metal bulge directly under the light, but it won't come loose and I don't want to force it. I doubt I'd get ticketed for this but I love the car and want to keep it in ship-shape. Any advice?
PS - As soon as I drove this car I knew I was born to drive a Buick!//
Old 01-26-2009, 11:55 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 LeSabre Custom - Third Brake Light
Turn the bulb socket 1/4 turn and it should come out.
Old 02-02-2009, 02:36 PM
Thanks! Got the bulb out and it's fine, however no power to the socket. Horn also doesn't work and multi-meter shows no power to that either. Engine comparment light is unplugged (since car was purchased) and the little dangling socket looks green/corroded inside. Could all these be related? All on same circuit? Bad fuse maybe?
Old 02-02-2009, 06:49 PM
HotZ28's Avatar
AF Moderator Elite
Check fuse #13 it provides power to the stoplight switch and from there to the third brake light. Did you have someone depress the brake when you tested for power? The horn & underhood light have nothing to do with the third brake light.
Old 02-03-2009, 07:37 PM
C man C man is offline
The bulb socket may also be bad. I you constanty wiggled and pulled on it to get it out you may have damaged it. I had to replace mine. New light and it still didn't come on. Off to the junkyard I went and got a new one and the light started working again.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 02-04-2009, 09:58 AM
The socket looks fine and it wasn't working with the good bulb in there even before I removed it, so I'm more inclined to believe it's an electrical and/or fuse problem.
Temps here have been around 0 all week - I'll check it out when it warms up this weekend. Thanks
Old 02-04-2009, 01:58 PM
The socket can look fine and be messed up. Mine looked like nothing was wrong with it but the connections inside the socket were bad. If you wiggled it would make contact and the light would work for a little bit and lose connection again. But I have the the lamp moniter control. Don't know if you do, so I could moniter mine real time.
Old 02-04-2009, 05:08 PM
Lamp monitor control?! I don't know anything about that... I have the poor-man's lamp monitor control - I back my car into a space in front of the 7/11 and check the window reflection to see if all my rear lights work!
Old 02-04-2009, 06:21 PM
Scrapper Scrapper is offline
AF Premium User
i'm suprised they don't think your going to rob them lol...because my luck that's just what they would think if you don't work there. again lol...
Old 02-04-2009, 09:22 PM
imidazol97 imidazol97 is offline
AF -Advisor
That provided my laugh for the day. Great comment. Guess it would depend on what part of town you're in on that too.
