Coolant loss
I have a 2003 Silverado 1500 4.8 L. with 120,000 on it. I am loosing about 16oz of coolant every 300-400 miles. There is no visible leak around the intake , hoses, water pump, coolant tank,or radiator. The oil is clean with no contamination caused by coolant in it. Could it be the intake gasket leaking into the exaust port on the head causing the cooling loss? The truck runs great except for this problem that just started.
Thanks. |
Re: Coolant loss
Also spray carb cleaner around the intake to see if you have a intake leak, engine will increase in rpm when carb cleaner finds a leak. |
Re: Coolant loss
As said do a pressure test and look for leak.
Test it cold and warm and hot. They also make a leak check dye to put in the coolant for the hard to find leaks. And will also show any coolant getting in the oil.
Re: Coolant loss
I have changed alot of water pump gaskets, they fail usually before the pump does. They leak right onto the engine and burn off before you even see a puddle. the easiest way to check is to let it warm up and slide under it and look at both sides of the water pump where they bolt to the engine. like I said ive done many of these for buddies and it has always been the gasket. I have done the 4.8s,5.3, and 6.0s and alot that I have done have over 100,000 miles on the original water pumps and are still going. I also flush and replace the coolant while I am at it, because it only makes sense to.
Re: Coolant loss
I'm having this same problem. Small amount of coolant disappearing and no evidence of where it's going.
2001 5.3L 110,000mi I'll have to give the pressure test a go and see what I come up with. P.S. I might be crazy, but it seems to leak more when it's extremely cold outside. I live in Western MN and in our last spell of -10 degree weather it seemed to lose quite a bit, compared to in the summer it hardly leaks.
01 Silverado Z71 5.3 BFG All Terrains Flowmaster Catback Silverstar Ultra High/low Sirius sat. radio More to come..... |
Re: Coolant loss
A lot of leaks are cold leaks. That is why check cold and warm and hot. Post back what you find.
Re: Coolant loss
My bet is that the wp gaskets are leaking and drying up before they hit the ground. If you are leaking get it fixed now, dex cool makes MUD whenever it hits air. I disagree with the previous poster though, if you are pulling the pump why not replace the pump at the same time, they are not that expensive compared to a cooling system that is full of mud.
If its not an external leak I feel sorry for ya. GM had a TSB to dealers about certain casting number heads being porous and leaking coolant internally. The ls blocks do not run coolant through the intakes, so if its not a porous head or block it may be head gaskets. Napa sells sniffers you can check the degas bottle for hydrocarbons, if you have a blown head gaskets it will have hydrocarbons in the coolant system.
10 hours away from John Deere master certified also master certified ASE tech. Exp. in both. Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training Gave up wrenching for "Greener Pastures" Current job: RN 2010 Silverado Z71 5.3L 65xxx Wife's 2007 Suburban 1500 LTZ 5.3L 102xxx |
