need help ?
..84 s-10 2.8..will not turn over by key..new parts.ignition coil/switch/starter
...new battery.new module in distributor...motor will turn over if jump at the ..starter.all fuses are good..clutch switch has a bypass.. plz HELP .. |
Re: need help ?
On the switch, you mean the lock cyclinder or the electrical portion of the ignition switch ?
Do you have power on the yellow wire off of the ignition switch when the key is in the start position ? Is there power to the yellow wire a the clutch switch ? If you have power on the yellow wire with the clutch switch jumpered, (Not a safe idea), do you have power comming out the other side, Purple wire, ? |
Re: need help ?
move about fifty feet and went dead have light but no juice above starter looked for fuse link non found..Thank You... |
