Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-25-2009, 10:14 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Best way to flush
power steering? I unhooked the return line, and I kept adding more of the new fluid because I had added shit ass fluid to it. But it still makes the noise and I've been through about 9 bottles. Should I just keep flushing it? Or can I some how force all of it out with vacuum?
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 01-26-2009, 11:06 AM
somick's Avatar
somick somick is offline
Re: Best way to flush
For starters I would keep the language more appropriate for the public forum. It is where we are!
Did you try to bleed air from the system? Haynes recommends turning steering wheel all the way to left and right few times with the engine running.
I hope this helps,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 01-26-2009, 04:07 PM
Yeah, I did all that stuff.
9 quarts of Honda PSF through the system, and there is no air in the system.
Me: No you idiot.
Me: FAIL
Old 01-26-2009, 05:51 PM
somick's Avatar
What kind of noise is that?
Could it be over or under tightened belt?
Try to put a mechanics stethoscope to the bearing. Considering the age of the vehicle (I assume it is one in your signature) it could be the culprit.
Sam
Old 01-26-2009, 07:00 PM
I'm ahead of you. I did the screwdriver stethoscope trick. It's the pump, but the belt I tried 890374 tensions. And as for the age, yeah it's a '94, but the pump is about 12 hours old. Maybe it's just because AutoZone is trash and the pump is bad? I called Honda, and they said after 9 qts and it's still doing it, it has to be the pump.
Me: No you idiot.
Me: FAIL
Old 01-28-2009, 11:29 AM
somick's Avatar
You should have started with that!!!
Whether we like it or not, Hondas do not like aftermarket parts! I wonder how much OEM pump cost.
I guess the junk yard is the solution.
Good luck,
Sam
Old 03-28-2009, 11:13 PM
Makellos's Avatar
Makellos Makellos is offline
What about flushing through the heater hoses. How effective is it.
Old 03-28-2009, 11:49 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Huh?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
