Old 03-23-2003, 04:02 PM
RaceMySS_454's Avatar
RaceMySS_454 RaceMySS_454 is offline
Send a message via AIM to RaceMySS_454
I hate my life (Paint Problems)
i just primeds and painted my ford lighting and when i went outside to look at it the paint was all chiped and ruff in areas and stuff.....im so pissed right now...grrrrrr.....what do i have to do sand and paint again.... than what have the same problem..
-RaceMySS
Remember....if it has to do with Woman,Wings,or Wheels...theres bound to be trouble.
Old 03-23-2003, 04:05 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
That sux man sorry to hear that
-Andrew-
Old 03-23-2003, 04:08 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Put it in brake fluid while the paint is still new, take it out 3-4 days later and the paint will wipe off if you hold it under a water tap. You can put in there for only 2 days, but I put the body in brake FLUID (not CLEANER) for 3 or 4 days just to be sure. good luck on your next paint job, remember, heat the can and always use either Tamiya or airbrush
Old 03-23-2003, 04:34 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
yea put it in Brake fluid, how long did you let the primer harden for? Theres probly a cause of why it did this
Old 03-23-2003, 04:36 PM
ok
i Primed at 3:30 its automotive primer......than i went out at 6:00 and see if it was dry it definatly was dry i touched it and stuff but not like touch touch just to see if it was dry.....than i applied the blac went inside at dinner did some work than went back out around 7:30...and thats when i saw the mess....
-RaceMySS
Old 03-23-2003, 04:49 PM
integra818's Avatar
Re: ok
-RaceMySS
So I guess you hav'nt read the FAQ ey? You're supposed to let primer harden for a full 24 hours . Just re-do it and I bet it'll came out very nice, good luck
