Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-25-2009, 07:46 PM
blitzin54 blitzin54 is offline
96 jeep GC 5.2 l miss fire code 43?
I have a 1996 jeep grand cherokee 5.2 l v8. I noticed it it start to miss fire and the check engine light came on. you can feel it misfire at an idle and while accelerating slightly but when u reach 45 mph it starts to misfire bad(feel it shake the car) and it seems to get better after 55 mph. took it in and got the codes ran, got the code 43 for multiple cylinder misfire in all 8 cylinders, checked most everything in the service manuel and nothing major seems to be out of place. i think it might be a sensor of some kind just wondering if anyones had a similar problem or if someone can lead me in the right direction......
Old 01-25-2009, 10:37 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 96 jeep GC 5.2 l miss fire code 43?
Welcome to AF.
It might simply be a maintenance issue. Unless you have done so recently, try replacing the spark plugs, plug wires, distributor cap and rotor.
Old 01-26-2009, 12:21 AM
discnik discnik is offline
Code 43: Ignition control signal from the PCM did not achieve the expected maximum current flow of 8 amps. The coil output circuit inside the PCM is designed to limit current flow to 8 amps, but this can only be reached if coil resistance is normal, the PCM output circuit is normal and full battery voltage reaches the battery side of the coil.
Check the battey voltage to the coil,(DG-OR wire), from the automatic shutdown relay. Check for normal coil resistance,(See below). The dwell time on the PCM coil control output should be near 4 milliseconds, (Need lab scope), with maximum or peak amps near 8 amps. The coil control wire is GY or BK-GY wire going to PCM pin A-7.
Ignition Coil Resistance
Primary (Ohms) Secondary (Ohms)
Diamond: .96 - 1.18 11.3 - 15.3 K
Toyodenso: .95 - 1.20 11.3 - 13.3 K
Hope this helps.
Old 01-26-2009, 07:51 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Moving to the Grand Cherokee section for you.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-02-2009, 10:41 PM
LordJebus LordJebus is offline
I recently ran into a 99 with a similar problem. Computer was giving a similar code, after 2 hours of waveform diagnostic, I went back to basics. Turns out one cylinder had no compression, melted the exhaust seat right out of the head and threw a valve. Check basics..!!!
Old 03-21-2009, 08:15 PM
GRABAWRENCH GRABAWRENCH is offline
HAY YOU KNOW I HAVE A VERY SIMILLAR PROBLEM AND HAVE BEEN GOING OVER IN MY HEAD AND YOU MAY BE RIGHT ON THE MONEY. I HAVE SEEN THIS PROB BEFORE AND TURNED OUT TO BE A BAD COIL. i WILL CHECK MINE OUT AND GET BECK TO YOU. THANKS, GREAT TO HAVE A SECOND OPINION.......NEVER GO TO GARAGE HAHAHAHAHAHAHAHAHA!!!!!!!!!!!!!!!NEVERRRRRRRRRRRRR RRRRRRRRR
Old 04-04-2009, 11:26 AM
Nope no luck, still there. Please anyone throw me a bone? Can't have a jeep down guys. Cant get muddy if it aint running thru da woods.
