Old 01-25-2009, 04:08 PM
heatherhmg heatherhmg is offline
Replacing locks in 85 blazer s10
I can't figure it out. I took the panels off hooked it up like the other lock was hooked up but when I put it in and try to turn the key in it the lock on the inside hits the window rail. Which brings me to a different problem my passenger side window when I roll it down it comes off the rail. I put it back on the two rails and if I roll it down it comes off again, what am I missing that holds it one there?
Old 01-27-2009, 12:38 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Replacing locks in 85 blazer s10
You have to take a look at the window rail and see if its damaged or is missing bolts. The window is pretty straight forward, just follow it down and see where it goes off its track.
Old 01-27-2009, 01:55 PM
is there supposed to be something that holds the side of the window. There is a hole in the window a circle one is there supposed to be something there and holds the side in when it goes up besides just the rail?
Old 01-27-2009, 03:50 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Those locks are specific to which side it works on I think. Turning it to unlock the driver's side is opposite that the passenger's. Make sure you got the right side.
As for the window, I'd compare it to the driver's side and see what's wrong/missing. A window coming out of the door frame track or turning crooked in the frame usually means a worn out regulator.
Between this and your tranny probs...you sure bought yourself one heck of a project truck. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-27-2009, 04:51 PM
I never thought of it being for one door and not another I'll have to check that out.
And ya I know its a project but I want to learn, checking my differential is one thing that I know how to do that I have been told to do. The other things I'm going to have to learn. I have a very minor background as a army reserve mechanic so I'm learning more lol.
