Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2009, 03:13 PM
JonathanH2286 JonathanH2286 is offline
97' eclipse Exhaust problems!!
I have a 1997 mitz Eclipse non turbo. I have replaced the gasket between the exhaust manifold and exhaust pipe that goes to the flex pipe. I have replaced it about three times with factory spec gaskets twice and made one from header gasket material for a chevy 454. It keeps blowing out and burning up the gaskets is there anything I can do to keep it from hapaning again? other than just keeping an eye on it!
Old 01-25-2009, 07:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 97' eclipse Exhaust problems!!
Are the bolts staying tight? If they are loosening up I can see it happening. Also might want to check the flanges for warping. I really doubt they are but its worth checking out.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-29-2009, 05:04 PM
I have checked the them. I have enven check them after I tighten and let the engine get to operating temp and recheck them. the flanges are not worped at all they have a diference of about .0001" on the over all diameter of them. I can't seem to find the leak and or the problem.
Old 02-26-2009, 09:30 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Do they blow out in the same place of the manifold or can you tell?
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 03-05-2009, 07:37 PM
They blow out at about 1/4" apart but usually are in the same area in the front facing the front bumper.
