Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 01-25-2009, 10:55 AM
grumpy247 grumpy247 is offline
front turn signals
97 firebird, hazards work on the front and rear, and rear turn signals work. i replaced the lamp sockets because the old ones were burnt, i thought this would clear up my problem but it didn't. help please !!!!!!!!!!!!!!
Old 04-01-2009, 10:44 AM
oldgray oldgray is offline
Re: front turn signals
The hazards and turn signals use seperate "flasher units" (can't think of a better name). Have you tried replacing that yet?
Old 07-20-2009, 07:39 PM
jackal342 jackal342 is offline
I'm having the same problem now, (just started today) the turn signals work sometimes and sometimes don't. I also noticed that sometimes my DRLs won't work sometimes on each side, but sometimes do. When the turn signals are working the arrow light will flash normal inside the dash, but when they are acting up it flashes really fast inside the dash and not at all on the outside. Its very annoying because I replaced my sockets too... I was having a problem before with my brake lights not working right, sometimes one would work and then it wouldn't and sometimes neither would work and sometimes they would both work just fine. This problem was fixed by replacing the turn signal lever and switch. Could it be this has gone bad again and is causing the same problem in the front of the car now?
Old 07-20-2009, 10:36 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Hey grumpy, check the wires inside the rear bumper. Don't freak out is not as hard as it sounds, all you do is take the rear tail light cover off (driver) and make sure the connector right under that cover (the one you took off) is not faulty. If you want to go all the way, take the other one off and the key hole for the latch. In total....3, and you'll expose all kinds of wires. I hope that helps...
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
